log or lin pots test
i found some 250k cts pots in my bits box but im not sure if the are log or liner. the markings on the back have been soldered over.
is there an east way to check
  • RolandRoland Frets: 8852
    edited October 2020
    Turn it to halfway. If the resistance is 125k then its linear
  • AlmachAlmach Frets: 105
    OK smartypants, what would it measure if it is log ?
    CTS have a data sheet for their 450G range of guitar potentiometers. It has a graph of the resistance curves.
    That depends on how it’s made. There’s a theoretical value, but different manufacturers and production methods diverge from that. However if the resistance is 50% at halfway then you know it’s linear.
  • ICBMICBM Frets: 73109
    edited October 2020
    What Roland said. There's more than one log taper - true log is 10% of the value at half turn, but there are other specifications which are usually called 'log (%)', or more strictly 'audio taper' - and some lower-quality ones aren't any proper log or audio spec.
    But if you set the pot to halfway and you get half the overall resistance from the middle terminal to each end, then it's linear since none of the 'log' tapers are anywhere close to that.
  • phil_bphil_b Frets: 2011
    well what ever one it is the volume only seems to work between 6 and 10 below 6 and it silent
    That and the fact that it's entirely covered with solder would indicate that it's probably been buggered by overheating.
    edited October 2020
    Maybe
    @ICMB ;; I just made my self a pickguard that has 2 pickups with a single volume and single tone. If I order new pots should I get log or lin?
    Log or Lin for volume depending on your preference - Log gives a fast drop-off from full, good for cleaning up an overdriven amp; Lin gives a smoother roll-off better for use as an actual volume control. Log for tone, always - unless you want all the sweep in the bottom quarter turn for 'hand wah' type effects.
    thanks for the explination
