I believe it is something to do with them having a reduced pull on the strings compared to a 'normal' non active magnetic pickup.
Worth a try as it is easy & reversible (measure your existing heights before adjusting anything).
Did you replace the pots with the 25K ones?
Maybe go through the wiring again and make sure you didn't put a connector in the wrong place
I guess I'll have to pull it apart again and take a look. Strats are such a pain in the ass with wiring problems, all the strings off again!
N 6mm, 5mm
B 4mm, 4mm.
My controls are 5-way selector, Volume, EMG-SPC mid booster. The latter is what provides the extra push for hard rock or metal sounds.
In my opinion, the VLPF is of limited use. The old, hard-wired, passive treble roll off tone control is okay after the capacitor value is changed to .033 or .047uF.
Just a thought: don’t the solderless kits have a couple of tiny screw connectors for things like the pickup selector switch? Double check that they’re all making good connections...
The best trick is on a Floyd - without slackening the strings at all, take the vibrato springs off round the back and you can lift the bridge out to get the strings out of the way, work on the electrics, reassemble it all and it will usually still be in tune .
1) The guitar wiring harness could be a hotchpotch of EMG, Duncan or Fishman Fluence parts. (If this were the case, it would have been mentioned in the opening post.)
2) Power supply failure.
All other possible explanations defy solving by telepathy.
Definitely improved by active EQ, but they are never weedy without
You can get broken ones, I think I had one broken used EMG once
Just make sure that the push on connectors to the back of the pickups are not on backwards
Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
