Ss shovan 3PCS HSS Step Drill Bits Set High Speed Steel Step Drill Cone Cutter - (4-12mm, 4-20mm and 4-32 mm) Cone Drill Bits Hole Cutter for Wood Stainless Steel Sheet Metal https://www.amazon.co.uk/dp/B077JKSFRJ/ref=cm_sw_r_cp_api_i_e7DNFbKTMG40E
just go slow and don’t apply too much pressure - it shouldn’t grab
You’re welcome.
They’re also very expensive, especially in the larger or specialist non-round sizes (eg IEC socket).
I have an old Peavey practice amp (originally 7W, 8” low spec speaker) which I’ve replaced the speaker for a PA midrange speaker, and will be removing the existing amp and transformer. Currently I’ve got an AMT preamp pedal externally wired to a small class D amp (I think from memory it’s 60W RMS?).
I might also add internal reverb at a later date, so will likely drill some holes for controls on the back too.
Also, I might drill holes for standoffs for the amp board. I’ll likely just use the self adhesive plastic standoffs initially as I’ve no experience tapping things. I’d like to get the final result as professional as possible, so it’s modular, robust and easy to repair.
they all seem much of a muchness. Neutrik seems sensible?
