Think of two people swinging a long skipping rope for an exaggerated version, the middle of the string needs more clearance from the frets to complete it's cycle.
A 'perfect' set-up with the neck dead straight and the nut the same height as the first fret would have an action of 0 at the nut, half the 12th-fret action at the 5th fret, and 1.5 times it at the 24th fret, but in the real world the nut will be fractionally higher and there will always be a tiny amount of relief, so the 5th-fret action will be slightly higher and the 24th (or 21st/22nd) fret action slightly lower.
I think I need to buy a cheap as chips guitar to start messing around with (tech).
