It's also easy to work with, not tricky.
I’d be very surprised that if it was stored somewhere with highish ambient moisture levels for a long enough period the white celanese would get damp/take in some of that moisture.
This type of cable was designed and used for voltages up to several hundred volts in equipment, and doesn't degrade significantly over decades - it's a complete non-issue at guitar voltages.
This is an absolute red herring - I would be far more worried about the effect of moisture on the rest of the electrics and even the wood than the cable, and if you're storing it somewhere where any of it is likely, don't!
Also, *pure* water is *not* conductive, which might surprise some people. The only reason water is normally conductive is because of dissolved salts.
But I still don't think moisture take-up is even an issue, so it's moot - just more vintage guitar nonsense.
Ooh, er, missus!
