Ignoring the listed price, what are your thoughts on this Musicmaster listed on
Reverb -
https://reverb.com/item/37719567-fender-musicmaster-with-maple-fretboard-1956-1959
It's a far from original guitar naturally, and what's scribbled on the end of
the neck is clearly done at a presumably much later date, but what would you normally expect to see there on a Musicmaster neck of this era?
And do the pickup and pots look correct?
The pots, tone cap and jack look original but the pickup has been rewound by the look of it, although the flatwork and magnets look right.
So really it’s a refinished neck, a damaged and refinished body, some original electrical parts and an original case... and even those aren’t worth a lot because they only fit these and Duo-Sonics.
Which makes the price very hard to overlook...
But I owned a short scale Musicmaster before and liked it a lot. I personally have no issue at all with varying scale lengths in electrics or acoustics.
The back of the scratchplate in the "pots" photo - it looks very much like metal under the chipped paint edge rather than plastic. I'm certainly no expert but can I ask why you think this is not original?
Cheers
The seller's offering a very substantial reduction but even so, it's all too mucked about with for my liking.
Like, 85% of the price? That might be more attractive.
Forum feedback thread. | G&B interview #1 & #2 | https://www.instagram.com/_harry_seven_/
Typically, this will manifest as circular white areas around the screw and jack socket holes. Crusty next to each hole, becoming powdery towards the edge.
