that braided hose needs replacing ...
The red arrow shows the hot water pipe which is connected directly via the flexi hose to the tap.
Unless the boiler condenser waste is dumped into the normal cold water pipe then somehow filtered at the junction where the Green pipe connects? Surely not. It cant filter anything.
Edit: Ah, @skunkwerx I see we were typing at the same time!
https://twitter.com/spark240
Reddit r/newmusicreview
They don't like being bent over like that and will eventually start leaking.
If you can force the hose into a more vertical position, perhaps using that horizontal slat to anchor it, it might slow the leak but if it's started already you'll probably need a replacement.
As and when you do replace it, try to keep the crimped part of the Flexi-hose vertical as it leaves the nut, if it's left to lean over like that it will leak again eventually.
Turns out there is an H in Haych! ~ Sporky
Bit of trading feedback here.
thanks man
The braided pipe relies on a rubber washer at the end to seal it, it shouldn't be angled coming out like that, it should be square.
I would isolate that pipe with the valve (those valves only turn 90 or 180 degrees so don't try to force them past that), loosen the large silver nut and replace the rubber washer, and put it back on with some PTFE tape along the threads, making sure the braided pipe comes out square rather than at an angle.
The green pipe will be a washing machine or dishwasher pipe.
Unfortunately the plastic gets brittle over time and tightening it can break it, you'd be better off getting a whole new hose and fitting that.
