The likeliest explanation is that the pickup and selector switch cables have been connected to the wrong terminals at the volume pots.
The terminal at which one end of the tone control capacitor is connected can make a difference to pickup loading.
The original Fender circuit used 1 Meg Ohm pots. Forty five years old budget Japanese pots might be dying on their arses by now.
Final thought. Are either you or the guitar left handed?
If your photographs reveal a complete dog's dinner, there is a case for reassembling using all new parts.
Hard to show in the photos
Tone control - cap 3rd leg - middle leg(white wire) wired to volume 1st eg
Volume
1st leg earthed to back of pot
2nd leg red wire to 3 way switch
3rd leg red wire from pickup - white wire to middle tone control
Pots are connected by an earth wire to the back.
What are you connecting it to?
Just strange as when either volume is rolled back even the slightest amount the tone controls work.
The 3 way works fine.
Just wondering if it’s some sort of load impedance issue, since the controls work when there’s a small amount of resistance between the tone pots and the output.
Never would have thought that it may have been the amp.
Thanks ICBM saved me alot if hassle as I was going to strip it all back and attempt a rewire.
I actually wondered if it was going to be a Pignose - those have a very low input impedance which does strange things to the way the guitar controls work.
