When I first got my AV65 Jazzmaster, it rattled. One of the little triangular steel thingies that fasten the control cavity screening plates had come loose. That could easily have bridged contacts across the Rhythm Circuit pots or switch.
On a Squier VM, CV or Mascis Jazzmaster, you have to wonder whether the slider switch itself is of adequate quality.
If you have had a budget JM screened retrospectively, the foil could be shorting against exposed metal parts.
