Probably a broken wire in the tank - especially given that it's obviously been dropped - but there is a possibility of a failed component in the drive circuit.
"1" which @casapete is selling here is the correct original one .
https://www.thefretboard.co.uk/discussion/204661/
Bit concerned at the fragility... I'm more interested in a simple reliable thing. But it would guarantee being the correct switch rather than risking a new one that might use a different scheme?
I'll take a look inside the tank after work. In order:
- remove rear plates
- remove baffle and speaker
- remove reverb tank
- fill holes in front of amp and baffle
- re-drill
- check reverb tank for obvious fault and solder if necessary (weekend job sadly)
- re-fit everything
- rock out
The footswitch is a tiny issue, a single button one will obviously work but the original one looks cool.
The holes in the baffle should be fine, the screws will just have pulled out of the cabinet. Don't re-drill - pack the holes in the cabinet frame as tightly as possible with wood glue and matchsticks (better than toothpicks for this, the wood is pine) and put it back together with the glue still wet, without drilling anything.
If I remember correctly a single-button one won't work, or not without replacing the plug at the amp end with a TRS with the ring unconnected, otherwise it turns the reverb off.
Yes, toothpicks and wood glue is a legendarily good piece of advice. I'll document as I go - thank you!
I think I'll get the original footswitch, just need my vox to sell first
Man, this thing is built... Impeccably. May be it has been worked on before as some screws seemed slightly chewed, as if some numpty didn't use the right size screwdriver.
Pictures coming this evening. Got to say though, the weight is the speaker. If this sounds as good loud as it does quiet, it makes me wonder why Marshall don't make these anymore!
Chewed screws on the inside where the baffle is screwed into the cabinet could be original, Marshall's workers seemed a bit brutal with those! I suspect they had the power screwdrivers set to 'no mercy' for those . But all the other ones should be pretty clean.
Exactly right. Got the baffle out and there are all-original wood shavings from the holes!
The amp... Looks nearly new.
I like how the valvestate 80 watt sounded but it wasn't my favourite amp - I'd take a bandit every time for sound quality.
Gut shots will be coming. Not sure about reverb, tank looks fine so maybe an issue with circuit. Not important to me but a shame.
It's so clean inside!
I cleaned the contacts for the reverb tank, and generally did a bit of dusting. Put it all back together, making sure everything was nice and tight. Plugged in...
Beautiful. Sounds great! Can't believe these are so cheap, great tones even at whisper volume. The cleans are "proper" Marshall cleans, not a half-arsed attempt at Fender. The drive is super responsive.
The reverb circuit... Works! It just doesn't seem to add much reverb - I wonder if it is dependant on volume. It adds a bit of hiss so it might be a bit not-working properly, but it does add a tiny bit of ambience when maxed out.
I wonder if it is something in the circuit, but I don't mind and I don't usually like spring reverb anyway...
Don't have time to upload all pics till tomorrow but this amp rocks. It's super solid, the chassis and internals were very tidy and the speaker choice is a good one.
Also glad to have taken it apart AND put it together in a couple of hours with poor light and not totally bork it!
Edit: I did use duct tape for the reverb cable relief. The nail-in clips were just too difficult for me to work in with my limited tools!
Yes, could be. It doesn't sound like reverb as such...
Is fixing the driver something an average-level idiot could fix with a soldering iron?
Side note - typical of Marshall amps of this era - the tapers on the pots are spot on. It's a 100 watt amp but it's easy to manage the volume, and it still sounds like a big, fat amp. No hair trigger.
They are... Hilariously undervalued if they sound better than my one. This is honestly a great sounding amp. The 5210 is supposedly a bit better?!
As for price... I don't know. I find the price of Marshall lead 12s to be silly - I paid less for my 100 watt amp than some have paid for the lead 12, which is great but... I think there is a lot more value in the bigger ones, especially given how easy it is to keep them quiet!
No time to play today thanks to epic work. It sure is a nice looking thing in the living room, though. It also has fiancée approval for volume.
On having a play through of Snow (yeah, I like rhcp, sue me!) she commented "that sounds just like the record". Pretty high praise!
Actually, I wouldn't even assume it was solid state - it has a very valve-amp sound and feel. It only becomes a bit more solid state-ish when the gain is maxed - this compresses quite a bit and rather than sounding exactly like a jcm800 it's more like a jcm800 with a boost in front.
Gain at around 3/4 gives a very responsive amp that works for a clean-ish with volume rolled back on les paul, rock rhythm maxed out or a lovely, super responsive bluesy rhythm with a strat or tele.
The clean channel is pure clean Marshall too, I'm sure I'll need to find use for it but I am pretty comfortable treating this as a single channel amp for the most part!
Pics should be uploaded today - very, very tidy build. It makes a pretty loud pop sometimes when turning off, which I may ask someone electricky to look at just to make it more apartment-friendly but whether whisper quiet or a bit louder it really does sound fantastic.
Marshall, if you're reading this, please please please make them like this again. Solid state doesn't need to be budget - just a good amp, good cab and good speaker. Forget including reverb, everyone has one anyway!
Reverb tank is an accutronics dated 1989:
Reassembled:
Also, at the input end of the reverb tank, is the black wire that goes to the RCA jack broken where it joins the terminal? If it is that would explain why the reverb isn't working apart from faint speaker pick-up.
