https://photos.google.com/share/AF1QipNS0hAjUI_zA9y2TVOmPhMegJldmvh___Vq3-7O68Ql3wu6bHbeYEVaDSFad7NP1g/photo/AF1QipPep8_jHi6ZRD7haZpg3lPlq-ywLCw59zWP8Rj1?key=dklRNloydjlDemtST1dLMkNIQng5MzRMeWxEVThn
https://lh3.googleusercontent.com/pw/ACtC-3dKzRB7NnXjBBIs0L4AI5C897vRa6OevgpFbmmMFD-bv46iQ8CHjZ37f0WrsW74bDyXVhepGw7e80FRZ7akuzp5HSjjVQCmqx377CJ4_TzJ5x-NcFaRP_cDgMeEtJw152a971nPVQjfRIm-h1hFmM1H5A=w1425-h
And I've stained the body!
https://lh3.googleusercontent.com/pw/ACtC-3ee_0HO4AAtlkQ_c4v2Vv12ekTY4PYsRRXiUafhpLHWs3nTZoVIyv5lepgyeRGuO0hiD_nAVGV8XX49sLw8r1GQi_5cpOOWKzSRAEkdyxRsBZZqof3ZBjD2NtGXSeXCIzLky2EPXfGNRHSgSh6p6lQPsg=w1425-h2527-no
I need to give the body at least one more coat, as there are some patches and in particular I've been having trouble getting stain into the bits where the neck meets the body, so have bought some foam sponge brushes.
Instagram
I'm not sure whether the neck perhaps needs a tiny bit more orange in the transition from red to yellow. I put the 3 colours down, then went over the orange in some yellow which created an interesting effect, but looking at it now I think maybe the orange doesn't look strong enough compared to the quite bold red and yellow. Thoughts are welcome!
Here's my attempt at natural binding. Needs a bit of clean up but I'm fairly happy with it given that I've never done it before, and as this is my first time staining I thought there'd be more bleed through.
Annoyingly, I've noticed there are some pores that still aren't filled after 3 applications of filler!!! So I may need to do a fourth application, though only in a few places rather than the whole body.
I would be tempted to seal the whole thing before doing any more grainfilling
Instagram
And under a very bright direct light which shows the figure but makes it look a bit washed out / makes the red to orange transition look harsher.
Unfortunately, this time I did get some leakage of stain onto the binding, so will need to give it a going over with some 320 grit.
After that, I just need to draw my headstock design with a posca paint pen, and then it's off for lacquering!
So the next job will be to install the machine heads. I'm a little nervous about this, because I don't have a drill press AND the headstock is angled. Does anyone have any tips for drilling the machine screw holes?
My plan is to fit the tuners without screws, align them using a straight edge, mark at the screw holes with a bradawl then use the ol' tape on the drill bit trick to stop me drilling too far, but I'm not sure how best to ensure I'm drilling straight.
I have thought about making a little jig by drilling straight down into a bit of scrap wood, but without a drill press I can't guarantee the jig will be completely straight.
For tuner holes through the headstock, it really does need to be straight. A drill press or simpke jig like you mention would be needed for this job. Obviously the simple jig would probably be needed to be made on a drill press
Instagram
https://lh3.googleusercontent.com/pw/AM-JKLWHgiVSFeB6Q10iqWTJ0Tlmy5g-yTXyRDnvF257dy1JAjHPO4R2YlKgD6p7I19gnMnCjoVLsO-tpdRF24qlVtoNuC3EM_OcuTt26F6iNnZ6lknhDvokwUNYG5gHbcOio2i1dc4JnEXb5MB4rBwlqXT_3A=w1442-h802-no
Stock, the single pull-switch splits the neck humbucker and adds the middle pickup, so the sounds are:
Switch down - neck humbucker, both humbuckers, bridge humbucker
Switch up - neck single coil plus middle pickup, all three pickups with neck split, bridge humbucker plus middle pickup
As modified, the tone control switch splits both humbuckers, and the volume switch adds the middle pickup in any of the other positions. So you can now get all combinations of full and split pickups, except for the middle on its own. Twelve sounds in total, very flexible but surprisingly intuitive and easy to use.
Interestingly, the *best* 'Stratty' in-between sounds are the original PRS ones - split neck with middle, and bridge humbucker with middle. Splitting the bridge as well actually doesn't sound quite as good - although it does on its own. The split neck alone sound (not available stock) is also wonderful.
The humbuckers are a pair of PRS Dragon IIs - replacing the original McCartys, which I felt sounded a bit bland in this guitar - ie Alnico IV, roughly 8K and 12K resistance. The middle pickup is a Duncan Vintage Rails...
... which I would be the first to say is a *terrible* pickup, on its own - probably the worst 'good maker' Strat pickup I've ever heard. But in combination with the humbuckers, it's great - it's so thin and hollow-sounding that it sucks all the mids out of the humbucker sound and leaves a very Strat-like approximation. In fact, I think the reason the bridge pickup 'Strat' sound is better full than split is because it allows the much lower-output middle pickup to dominate the mix even more.
Given that, and even though I use the middle pickup a lot on a proper Strat, I actually think it's a good thing that it's the one combination you can't get on it .
If you don't want to risk a Vintage Rails (and I wouldn't blame you...) the pickup you need is something similarly low-resistance and thin-sounding by itself.
