Greetings folks,
Having attempted a Burning Water style finish (and been quite pleased with the results), I'd like to up my game a little and try out the Shmear finish they do, much like this one.
Tyler Japan Studio Elite HD Black Shmear Black Headstock Rear Rout Rosewood Fingerboard (guitarguitar.co.uk)Looking at the Burning Water/Vomit finishes, I think the Shmear may be used as a base layer too. However, Im not sure how to go about it. To me it looks like 2 slightly incompatible/non mixing lacquer have been applied wet. But I would very much appreciate any advice from the finishing guru's out there.
What lacquer/paint would you recommend, how would you apply them?
It may be possible to achieve this with a dipped paint effect (which Ive never done), so advice on doing such a thing would also be greatfully received.
Many thanks,
Adam
P.S. If anyone has any poor condition Squier Silver Series they would like to sell on, please let me know!
so likely a poured effect similar to this kind of thing - with all the challenges of doing that on a weird shape
Instagram
it gives this kind of effect
Instagram
I started with black, silver and clear acrylic pored into a little shot glass similar to the acrylic pour technique. poured it on and let it run. paints a bit thin so it ran straight off, but promising
I added some silver drops straight to that and lay it flat. after about 10 minutes i pulled the silver through the black with the end of a pencil
I then left it stood at an angle so it could start to flow out - which i think starts top get close to the desired effect
would take a lot more practice before I was happy to try it on a guitar though
Instagram
Cheers,
Adam
I think viscosity and timings will be important. .. but it seems to be a mix or pour, tilt, fiddle etc. I suspect Tyler drag the finish across in streaks, then let it run
Instagram
Do you think they cure hard enough for a guitar?
I wonder if using jets of air might be a way to achieve a softer 'streaking' effect?
But yes, i agree that the viscosity/timing/(?ambient temp) will be important.
Instagram
Great gen lads...
