Traded
mrn1989mrn1989 Frets: 240
edited July 2021 in Amps £
Great Marshall style amp but I could do with some funds for another project at the minute so letting it go. Sounds great, very versatile and has plenty of tight low end on tap due to the sealed enclosure design and buckets of volume but also does bedroom level due to the master volume. Comes with Mesa footswitch and Mesa slip cover, which has a tear on one of the corners but works fine, and Mesa casters that can be slid off so it sits flat on the floor, I have also made a splitter so the footswitch can be plugged in on the back panel, never really been a fan of footswitch inputs on the front panel.
Andy Timmons used the Deuce (100W 4 power tube version) in his rig, sounds great
Negatives
It took a knock from a flight case which dented the panel on the back and chipped a little on the rear panel but no structural damage or breaks.
Full Spec:
  • Handcrafted in Petaluma, California
  • 50 Watts, Class A/B Power / 2xEL-34, 5x12AX7, 1x5U4
  • 1x12 Celestion Vintage 30
  • Fixed Bias for Consistent, Maintenance Free Performance
  • 2 Fully Independent Channels with 6 Modes (Channel 1 = Fat Clean, Tite Clean or Crunch (Cloning Channel 2), Channel 2 = Crunch, Tite Gain or Fluid Drive)
  • Channel Assignable Dual Rectification with Recto Tracking™ (Diode or Tube Tracking)
  • Independent Gain, Treble, Mid, Bass, Presence & Master Controls per Channel
  • Bold/Spongy “Variac” Switch
  • Output Level Control (over all channels when activated)
  • Footswitchable Solo Level Control (over all channels when activated)
  • Fully Buffered FX Loop with Send Level Control (over all channels when activated)
  • True “Hard” Bypass Switch that removes FX Loop, Output Level & Solo Level Controls from signal path
  • Slave Out with Level Control
  • Fan Cooled
  • External Switching Jacks for Channels 1, 2 & Solo, Front and Back
  • Aluminum Chassis
  • 2 Button Footswitch (Channel 1/2 & Solo)
Looking for £750
Collection only from High Wycombe (J5 M40) due to size and weight.
A demo of one of these by GuitarGuitar:
https://i.imgur.com/Y2uEnjj.jpg
https://i.imgur.com/4KdFf25.jpg
https://i.imgur.com/i1uuq5u.jpg
https://i.imgur.com/2xJ1KOB.jpg
https://i.imgur.com/Gb9ZC8R.jpg
Fretboard Feedback https://www.thefretboard.co.uk/discussion/58705/  ALSO Over 500+ 100% feedback eBay transactions
