They’re probably the worst machineheads fitted on any modern guitar, but you could actually just replace the gear if you prefer - they can be taken apart easily. If you’d prefer to do that I could send you a selection of gears.
If you would prefer to replace the set, you need to decide whether you want the higher-quality diecast type with a threaded front collar - these need the headstock hole opening out at the back, which is a more complex job - or the vintage pressed-steel type, which will just need two new screw holes.
It is those offset ones with two holes, yes. I've always known they were cheap but they've worked alright!
I'm sure the others won't be far behind so I don't think it's worth repairing this one but I appreciate the offer @ICBM , thank you.
As to your advice for replacements, I'd be happier to not have to drill out the actual peg holes, I suppose, unless it was really worth it.
I just kind of hoped there would be an obvious option!! Like for 40-odd quid? Sounds reasonable?
for a tenner. I don't know if they will fit but it is worth a try (the dimensions are shown in the last picture on the listing). There are other options with the offset two screwhole type for around the same price. Just do a search on Amazon for "Guitar Tuning Machines"
