The 6505 just saturates into a great rhythm crunch tone on the lead channel with the gain at about 3 or 4. I worry the jet city can't match that with the gain maxed!
My friend is planning on getting one and at some point I'm going to try to get to a gearfest or something with one though. So far, 6505 is winning but only because of the familiarity with it. Used, they're about 350-4)0 quid for the USA head, too, which is good value.
Still works out about twice the price of a jet city including the cab. Unless I can shift my digital piano, I won't have room for a 2x12...
They have a "design quirk" which means you get some bleeding of channels. So if you keep the gain low on the 1st channel and whack the volume up to get a nice clean tone, and whack the gain up on the 2nd channel and the volume too... the 2nd bleeds into the 1st by quite a bit. This didn't suit my tonal preferences, so the amp went back.
But cracking sound. If I was just recording, would've been perfectly happy with it.
Wonder if the 'quirk' can be fixed.
It's holding up well so far, with plenty of volume on tap, even though yesterday's street gig was unmiked.
Considering I just bought it for my living room it's doing pretty well!
Also agreed. The schematics seem to be pretty close. Obviously parts on the Soldano ones will be better, the transformers etc.. But you're getting 90% (remember, 87% of statistics are made up) of the way there for a little over 10% of the cost. Others may disagree, but in my book that's a score, and makes it very hard to justify the more expensive one, at least for my situation (not gigging
It's sort of academic since these weren't available when I got my Engl, and admittedly my Engl is way more versatile, but for the tones I use most, had the Jet City been available I'm not sure I could have justified going up to the price of the Engl- or even wanted to spend that much, considering how good the Jet City is for the money. In fact, for those type of tones I may even prefer Jet City/Soldano type tones to Engl (unfortunately I wasn't able to try a Soldano before I got my Engl, grrrr).
