This will get you into the ballpark.
You could add a small amount of distortion too.
There is a Vangelis soundpack for the Mininova you might like to check out.
Apple Logic Pro has a bunch of Mellotron sounds lurking within its library. (Give me time to locate exactly where in the Directories.) Not sure about Apple Garageband.
Failing that, there are plug-in instruments that specialise in Mellotron, Chamberlin and Optigan sounds. Some of these also do string machine sounds.
