AndyJP said: That device might be the answer but it is outside my budget by a considerable margin. Is there a basic drive pedal for <€100 that will do the job I need?
Nil Satis Nisi Optimum
https://youtu.be/6EFRzuIJnbo
The Joyo American Sound is another budget option that gets a lot of love, there were some others in this range but it’s the American Sound that seems to have lasted. It’s hard to really say but I think this is more amp like than the Caline Pure Sky, based on YouTube demos…
My amp is a Dennis Cornell designed Stinger SE valve amp that I assembled from a kit which one of the monthly Guitar magazines had on offer well over twenty years ago. I believe it gives somewhere around 12 watts into a 10" Jensen speaker.
Nothing is easy when an electric guitar is used with an unamplified acoustic guitar and an unmiked singer.......
Problem I suppose is that there are so many possible ways to try to do this.
set the gain to where you want it, add in a bit of the clean blend if you fancy and turn the output volume down!… it’s not rocket science
I had considered getting a THR @munckee but I already have too many amps in the house.
