Strat shed its skin
maharg101maharg101 Frets: 781
edited October 2021 in Making & Modding
I always hated the poly finish on my strat.
It's just a MIM 70s reissue in natural finish. The finish was starting to lift, so I broke out a hairdryer and a plastic bicycle tyre lever and went to work.
Now she's as nature intended.
http://imgur.com/gallery/g6Ea8bq
This one goes to eleven
Trading feedback here
  • meltedbuzzboxmeltedbuzzbox Frets: 10343
    Looks like a yamaha pacifica
  • maharg101maharg101 Frets: 781
    It's going to Bob Cross for a new coat tomorrow :) will look less "pacifica" after that
  • You're a brave man, but it looks like you've done a good job on that. I'll bet it will look lovely once it gets its new coat.
  • DrBobDrBob Frets: 3043
    Did you measure the weight difference before & after ?
  • @CasperCaster thanks - haha yeah, it was lifting in a few places, then I noticed a crack in a patch on the back, then one thing led to another !! As you can see in the picture, the coating on the front nearly came off in one piece !! The horns were a bit trickier, but not much. The pointy end of the plastic tyre lever was just right for lifting it off once softened up with the hair dryer.
  • @DrBob no, I should have ! There was an absolutely shed-load of it. Noticeably thicker on the front...
  • GoldenEraGuitarsGoldenEraGuitars Frets: 8887
    “She”? ;)
    Good question - a few years ago on one of the US forums someone used the heat method to strip a Baja Tele. For a while those guitars were marketed as having a 'thin skin' poly finish. Anyway, the finish on that Baja weighed nearly half a pound. By comparison a good nitro finish may only be 1 or 2 ounces.
  • “She”? ;)
    and people are asking about her weight...
    I thought that was on here ? Wasn’t it one of the pedal builders was it Juansolo ?
  • “She”? ;)
    It's ok, she's thick-skinned.. or was ! ;)
    “She”? ;)
    As long as no one mentions playing with her knobs or nut, because then I’m definitely out
  • Tempted to refer again to the crack on her back side but let's not go there..
  • DeadmanDeadman Frets: 4159
    edited September 2021
    What finish are you going for? I hate that thick poly too.
  • Cellulose lacquer, natch !
    Cool. Any colour/tint at all? Pics when it’s finished :+1:
  • No colour, I love the natural finish, and it's a decent enough piece of wood. I will definitely post pics once it's done.
    Here's a picture before the poly was stripped off. It's hard to make out, but the poly is bubbling around the socket and the trem. When it starts to lift, it takes on a milky-hue and makes a hollow noise when you tap it.
    Other mods to this MIM 70s RI include a Tusq nut, Kluson tuners, fretboard re-profiled to 12" (from 7.5") and re-fretted with medium jumbos, Tonerider Surfari Alnico III pickups, Aluminium pickguard shield. Oh, and a bolt in the (unused) tremolo arm hole ;)
  • YorkieYorkie Frets: 1691
    I love it.
    Adopted northerner with Asperger syndrome. I sometimes struggle with empathy and sarcasm – please bear with me.
    My trading feedback: https://www.thefretboard.co.uk/discussion/210335/yorkie
  • Yorkie said:
    I love it.
    Thanks @Yorkie :)
    Newbie question: What wood is that?
