Trading feedback here
The back of my Tokai 335 squeaks when I change playing positions
You can use 400 to get the old oil off the surface then 600 for a smooth finish. Try and get paper that is not black or grey as it will sit a little bit in the pores or just give a proper wipe with lighter fluid before the oil.
https://www.thefretboard.co.uk/discussion/235/oil-finishes-little-tutorial-for-my-wet-sanded-oil-finish-technique
whatever you do, lots of rubbing and buffing is key
Instagram
You can rub down with 0000 wire wool and wax (with pickups masked). this gives a smooth satiny finish
Or you can totally rebuff with micromesh. This still looks gloss if taken to 12000g, but the lack of buffing compound used makes it feel less squeaky
Instagram
You just need to degloss it really
Instagram
