SOLD - Fender USA Jeff Beck Signature Stratocaster 1990's
![Image: https://i.imgur.com/Wv2QXQh.jpg](https://i.imgur.com/Wv2QXQh.jpg)
Fender USA Jeff Beck Stratocaster.
It comes with it's tweed hard case, tremolo arm, and I have a backplate and screws for it in a padded ziffy bag in the pocket of the case.
Lovely guitar to play. Some normal wear on the first few frets which have no effect on play. The previous owner had at some point put a humbucker in the bridge position, but had the sense to keep all the original pickups and wiring intact, and as you can see it's all back to original now, but the original pickguard has ended up with an extra screw hole etc because of the earlier changes. But, also included is a replacement Pickguard as pictured, so all you have to do is have your guitar tech swap everything on to it if you so wish, and you're as good as new. The vintage white has aged almost yellow and has lots of lovely checking.
The rich dark Rosewood fingerboard on this looks very special indeed.
Body: Alder
Neck: Maple
Neck Shape: Nice early Jeff Beck neck shape.
Radius: 9.5"
Scale: 25.5"
Nut: LSR Roller Nut
Nut width: 43mm
Fingerboard: Rosewood
Tuners: Sperzel Locking Tuners
Pickups: Original Gold Lace sensors and Gold Dually Lace sensor in bridge.
1st Fret Neck thickness: 0.90”
12th Fret Neck thickness: 0.94”
Neck width at 12th Fret: 51mm
Bargain price, only
£1295
Located in Portree, but I'm over on the east coast as well if it helps, and of course I'm happy to post via UPS.
Now Sold, thanks to buyer, and of course to the forum.
Good luck with the sale. I'm sure it won't hang around long.
And to anyone reading, I've bought from @MikeS before and he's an absolute gent.
