A video from Stewmac popped up on my computer, the video shows how to fit a 5 way switch on a Telecaster. Apart from the usual 3 selection options, it offers humbucking and an out of phase combination.
I have a USA built Fender Tele that I like and am 'thinking' about buying one of those switches and getting a Tech to install it for me. Does anyone here know anything about these switches and/or are the additional sounds on offer worth the effort installing the switch?
Apologies if this subject has been dealt with in the past. Thanks for your replies.
Nil Satis Nisi Optimum
The "humbucker" selection is actually two single coils, connected in series, in phase. It will only cancel hum if one pickup is built RP/RW with respect to the other.
For reasons known only to Schaller, their circuit does the phase reversal via the bridge pickup. This requires ground conductor modifications between the baseplate and the coil start. (As opposed to on the neck pickup cover.)
You often still need to get the bridge off though, because the bridge ground wire and the pickup ground wire are both connected to a terminal screw in the body (which also grounds the shielding paint) rather than both being led separately back to the control cavity.
1. 50s broadcaster bridge
2. 60s bridge
3. neck and 60s in parallel
4. neck
5. series
You can do the same with a rotary switch, but it’s harder to operate, and you can’t tell which position it’s in without looking.
If you fancy trying the series sound the Baja Tele has a series sound on its 4-way, and I believe the current Vintera version of that guitar retains that selection - if you know anyone with one of these, or a local store you could try it? The stock out of phase switch on the Baja (S1 down) is not a HOoP sound, just the regular thin out of phase sound.
I presume you are aware that you will have to separate the earth from the neck pickup cover (unless it's already three wire) for this mod.
http://www.thefretboard.co.uk/discussion/89942/caspercaster#latest
There's a few cap modded positions, a standard tone circuit, and a blower, guess which position it usually lives in.
This, in turn, demands that the metal screening part of one pickup should now be grounded via a separate insulated wire.
It is less work to perform this modification on the neck/Rhythm position pickup.
On Telecasters with a humbucker that has four-conductor output cable, it should be unnecessary to perform the modification at all.
Series, in-phase is louder, with increased midrange. IMHO, more overwound P90 than humbucker. This makes it useful for overdriven sounds and overbearing for clean.
Series, out-of-phase is oddly honky. Loud and scratchy clean but kinda Brian May Red Special with high gain.
Parallel, out-of-phase is horrid and wiry à la Smells Like Teen Spirit intro. Add a capacitor to the ground side of the neck pickup as a filter and you get the "half-out-of-phase" sound mentioned by CasperCasper. Much more like the Stratocaster in-between sound.
Even then, I'm not sure it's actually less work to do it to the neck pickup than simply snipping the link wire on the bridge pickup and adding a separate bridge ground wire - which in my opinion is an improvement anyway, since on old Teles it's not unknown for enough corrosion to get into the contacts between the pickup height screws and the bridge to make the grounding less effective.
W. R. T the original query about the 5-way mod with additional series and phase/HOoP sounds, it is my opinion that it makes more sense to snip the earth to the neck pickup cover and either earth it separately or not depending on your views on the sound of the neck pickup with/without an earthed cover and/or noise issues.
If you wish to perform HOoP with the bass cut on the neck pickup it will be necessary to mod the neck pickup anyway, since hot and earth to the neck pickup need to be reversed for the out-of-phase sound. You no more want the neck pickup cover connected to the hot side of the circuit when phase is reversed, than you would during series connection (assuming the 'normal' version of series connection, where the bridge pickup is the earthed coil and the neck is the hot coil).
I do agree that a separate string ground under the bridge is a sensible precaution on Tele's, rather than relying on the path from the bridge pickup.
Just my opinion/experience.
