Just got and fitted a new (to me but actually about 14 years old) bridge pickup for my Tele and I think it is microphonic, when I tap or even rub the body of the guitar I can hear it through my amp and if it tap on the pickup it sounds like tapping a microphone. It doesn’t do it with just the neck pickup selected.
My question is, is there a way to stop this, the pickup itself sounds great… if I stay completely still and don’t touch anything
Edit: done some more research and it sounds like the base plate is loose, any suggestions on how to affix it properly, for full disclose I had a Monty pup in there before and all was fine.
If it turns out the pickup isn't actually microphonic, or not particularly so, and if you've used springs for the height adjustment swap them for soft rubber tubing. Also, before fitting the pickup, check the bridge plate itself is flat on the underside by trying to rock it on a flat surface or rocking a straight edge against the base of the bridge plate - some of the vintage style plates are poorly formed/become slightly warped, including genuine Fender ones. If it's excessively wonky even relatively soft timber and lacquer won't offer enough compliance, and it may lift, particulary on the front edge furthest from the mounting screws. So, when installing the bridge tighten the 4x bridge mount screws enough, but don't over tighten them/distort the bridge plate. If the string earth is trapped beneath the bridge plate then sometimes just moving it a bit/ to a different position/ flattening it a bit can help. It also might be worth damping the pickup (foam underneath) or bridge plate.
http://www.thefretboard.co.uk/discussion/89942/caspercaster#latest
You could try warming it gently to soften the wax *a tiny bit*.
I then let it cool slowly (we ate dinner!!!) and stuck it back in the guitar. Hey presto!
Obviously this won’t work if the pickup isn’t potted but it may be worth a go…
Instagram
I will report back
Air gap between guitar bridge and guitar top.
Air gap between pickup bobbin and metal baseplate.
Sloppy height adjustment screw tension springs.
Poor/non-existent coil wax potting.
Shallow pickup cavity.
Coil so bulgy around its middle that the waxed string protecting it touches the edges of the pickup cut-out in the bridge, sending all vibrations directly into the coil.
I have used a feeler gauge to pack superglue in the gaps and left it clamped up. Fingers crossed. Thanks for the tips, I will check it tomorrow and report back!
