Sonic Koalas Albums https://sonickoalas.bandcamp.com/
!!! Wait what?! So what's your setup going to look like then?
Tell me about them
I am, I like it a lot.
@blobb
Thanks for your thoughts - appreciate it !
Am I right in thinking that i cant use effects from Beebo AND Digit at the same time ?
Hence the need for two ?
I've got one coming tomorrow from Andertons
You're not getting the full benefit of the unit and I think there are better sounding individual sounds elsewhere to be had.
If you want to have lfos controlling depth on a flanger and splitting off sounds in stereo to feed a bit crusher and some mental delay with a separate clean signal all at once then you are on the right track.
I haven't switched mine on for a while and I am sure I am many update versions behind but I can't remember how instant patch swaps are. I see to recall there is a delay.
I love the thing. Works brilliantly for recording and more esoteric uses
the other aspect is I never found a way to engage/disengage a footswitch and the effect consistently via midi. I could engage the footswitch or the effect but then they’d be out of sync with each other. Resolve that and it the world is your oyster.
