Bass synth pedalboard thing
Just musing about a basic foot switch synth for bass tones.
I imagine a long strip pedal with 13 non-latching foot switches in the keyboard formation… and maybe a three way toggle switch on the side. This plugs straight into a bass amp and with some cunning internal electronics… you have a full bass, single-octave, sound generator… the three way switch providing Sine, Saw and Square wave forms… maybe a couple of pots providing frequency and volume settings?
 The thing is, I’m not any kind of electronics designer, or synth maker, just how difficult would a project like this end up being
  • Depends what you expect the device to do.
    With a single oscillator, every new note abruptly ends the previous note. Gliding smoothly between two consecutive notes requires controllable Portamento rate and, more significantly, key scanning.
    The electronics to make this happen is, indeed, cunning … and expensive.
    Probably smarter to purchase a pre-owned MIDI bass pedal controller and hook it up to the synth module of your choice.
    A bass guitar amplifier may not be the best choice. The synthesizer deserves uncoloured full-range frequency sound reproduction and the absence of overdrive.
    Be seeing you.
  • DCS222DCS222 Frets: 35
    Cheers @Funkfingers ;That’s a shame... I thought I could probably use the echo unit or reverb on the amp (tc electronic tone print) to give a bit of tail to the notes... I’ve a bass amp and a monitor, so I could play with what sounds best. But it was the idea of a fairly simple noise generator to add width to a song if there’s just one guitarist... if the idea worked in a basic way, then move onto improvements.
  • RolandRoland Frets: 6248
    How about using a midi footpedal to control a synth module? You might need to chain two pedals to get a full octave, or you could use a single FCB1010 if you re-programme the bank up and down switches to note on/off.
    Known here as Old Misery Guts or the Big Bad Classified's Sheriff. Also guitarist with  https://www.undercoversband.com/.
    I wondered about something like that, but the FCB1010 would still be only 12 keys, I’d have to decide which note to leave out... (I was never convinced about F#) And it is £110 plus synth... which I was hoping to be less than £50 quid in the trial phase.
    (maybe I need to be realistic)
  • For £50 you might be able to do something like this ...
    Same kind of thing with some scavenged organ pedals ...
    But for £127, that Doepfer looks a lot less hassle.
        My 'Guitar diaries' on BandCamp
        My Soundcloud stream
    Ok, first steps taken… I found this Yamaha organ on FB that “all lights up, but doesn’t make a sound” going for free. It has a full octave of foot pedals, so if I rob only that part, I’ve got a head start! But I’m hoping there is other useful trinkets inside that may help the build…
    https://photos.app.goo.gl/ZSGrzujXdMAk5krF8
  • FunkfingersFunkfingers Frets: 9594
    edited October 2021
    If I recall correctly, one of the @HarrySeven ;Spring 2021 gear clearout Discussions included organ pedals and/or MIDI bass pedal controllers. I do not know which items sold and which went into storage whilst H7 moved to his new, underground, Bond villain style lair. Try sending him a PM.
    Be seeing you.
  • HarrySevenHarrySeven Frets: 6331
    Long gone, sorry! :(
    Mwahahahahahaha! <— Evil supervillain laughter.
    Forum feedback thread.    |     G&B interview #1 & #2
  • prowlaprowla Frets: 3897
    Shame you're not in my neck of the woods (Berkshire), as I've got a pedalboard off an organ which I acquired for a project which is never going to happen.
    Ok, I brought the none functioning Yamaha fe50 home… started to strip it… cleaned up a little and used some contact cleaner… the whole thing works no problem! So a little quandary, do I do summat with the whole beast or go ahead with my plan.
    I think I’m gonna carry on with the pedal build… so if you, or someone you know, wants some cheap organ bits… stump up for postage or come and collect.
    I’m keeping the foot keys, foot volume pedal and output amp/speakers… but there may be some handy bits!
    https://photos.app.goo.gl/NmzbenG5mrdvshfZ7
  • The FE-50 uses 4-operator FM synthesis. This is good at some sounds and weak/unconvincing at others. Thus, IMO, full refurbishment will be a lot of work for limited reward. You have nothing to lose by stripping the FE-50 for parts.
    Be seeing you.
