Is there any sensible/achievable way to shift a Strat selector away from the flailing of a non-Strat person who habitually knocks the selector when it's on the neck position?
I'm guessing it might mean a bit of chiselling or routing, or a new pick guard, but is this a thing?
In an ideal world I'd move the volume a bit away from the bridge pickup too and maybe just make do with a master vol and tone, but the main thing is the selector switch.
I'd assumed that if I googled I'd come across people who have successfully done this but I didn't.
Red ones are better.
Cheaper and easier to address your technique
The simplest thing to do if you don't use the bridge pickup much is just to reverse the switch, but it takes some getting used to...
Gigink.Co.uk will make one with the holes where you want. 1 vol and 1 tone either using the 2 furthest normal pots on a strat, or put them in between where regular strat pots would be.
Ive never moved the switch though.
That said, I find rotaries too awkward to use on a gigging guitar.
Is that so the first time you hit it, you cut your hand and hence shorten the learning process to not move your hand there?
http://www.thefretboard.co.uk/discussion/89942/caspercaster#latest
