Earlier in the year I build a Magna Vibe from Jeds Peds which was shortly followed by their Swamp Thang kit. The two have become favourites and at this time all the modulation I need. I squeezed them into a single box with a small switch to select. A few months later I thought, wouldn’t it be cool if…. and the results are show below (pre final wiring and finishing). So it’s a 1590B (the real Hammond ones are so much nicer BTW) with two footswitches but since neither of these are ‘hit quickly on the fly’ kind of effects it works fine for me. It’s a bit more untidy now as I had to squeeze in a volume trimmer for the Swampy which as standard has a bit of a volume boost.
This is the truth from hillbilly guitars!
