Using the Stringjoy calculator the nearest I can get is 15-20-28 38-50-56 for 173.6lbs, which is just slightly more than the 173.5lbs of their standard 12s on a standard scale.
Id pop on 13s to start with & if you want more tension the elixir nanowebs seem stiffer than equivalent non-coated strings.
