Some more router cutters. A few dozen sheets of MDF for all the templates. Some nut slotting files. A better soldering iron. Clamps (you never have too many). A cordless drill (ditto).
OK, maybe for trimming the braces of an acoustic, but other than that, I've just used routers and rasps. Guess it's what you're most comfortable using though.
Maybe some gouges?
Instagram
All good ideas, as is a set of Forstner bits if you’ve haven’t got any.
These are the ones I use exclusively for guitar making - I find the stubby ones much, much easier to handle for this kind of work:
Crown 4 Piece Butt Chisel Set | Axminster Tools
But, as @more says above, they do need to be kept razor sharp. Skilled folk can get away with just a two-sided waterstone, but I'm not and use the Veritas Honing System jig with a couple of double sided diamond stones...which, together, cost more than the chisels...
