It's rarely as dark as the "mahogany" colour you see on furniture or wood stain
Instagram
Nato/nyatoh/mora is similarly pallid in the raw.
I've seen some very light pieces that would probably take stain slightly more predictably, especially on ebay bodies.
Instagram
But I have had identical planks with massive weight differences between them, so take it with a pinch if salt.
Instagram
It's a bit academic if you are having it stained, but freshly cut and/or sanded timbers are almost always lighter in colour than they will be once almost any type of finish is applied.
This is the back of one of my builds in progress:
And this is the colour it was after I put clear varnish on it. No stains - just the above plus the clear varnish:
The neck is mahogany, by the way.
pics are raw and sealed from the wood database www.wood-database.com/
Cuban Mahogany -Swietenia mahogani
Honduran Mahogany - Swietenia macrophylla
African Mahogany- Khaya
Sapele - Entandrophragma cylindricum
Spanish Cedar - Cedrela odorata
Argos mahogany
Instagram
Instagram
Instagram
• Youtube - https://www.youtube.com/@Goldeneraguitars
https://imgur.com/dqMc92W
