Bridge Fix - Tite Bond Curing Time
Following lots of useful advice from everyone here at the end of last year, I removed and refitted the bridge on my Faith acoustic on Sunday.
The bridge was glued with Titebond and clamped on Sunday afternoon, I'm planning to remove the clamp and hopefully fit a set of strings tomorrow (Tuesday).
There seems to be varying opinions on how long Titebond takes to cure - does the team think that Sunday to Tuesday is sufficient time?
  • davrosdavros Frets: 1524
    I believe its 30 minutes for non load bearing and 24 hours for load bearing. I normally leave most things overnight with no trouble so 2 days should be more than adequate!
  • Chris.BChris.B Frets: 312
    @davros that was quick! Thanks Davros for a quick and helpful response.  I'm hoping that the Faith will live again.
    No probs!
