That's just the lazy option - it's like no-one could be arsed making a decision at the R&D meeting and just went 'meh, let them decide!'. It's like those pedals that let you use battery or PSU.....![;) ;)](/plugins/EmojiExtender/emoji/fb/3.gif)
Serious though I think in the world of TB vs high quality or highly dubious buffers then this is probably the best marketing option. The obsession of the TGP crowd over pooh-poohing something because it's buffered without actually having tried it is insane, especially when the next page features fawning over a £100+ buffer pedal.![:s :s](/plugins/EmojiExtender/emoji/fb/17.gif)
Bandcamp
Spotify, Apple et al
^^^ +1 on what ChrisMusic is saying, that's all I'm trying to say. There are a lot of things you can do to influence people- even the choice of the pedals for the test is important.
You'll note that all those pedals were more expensive than the Visual Sound one- that set the thing up, from the start, as a win-win situation for VS. Now, happily for them, the people liked the VS one the best (the cynic in me wonders how many vids they had to make before that happened, though admittedly as they said, they're all pretty similar pedals apart from the centaur so it's entirely possible that people liked the VS one better; I'd be the first to admit that dearer pedals aren't necessarily better)- but even if they hadn't, Bob Weil also got them to admit that they all sounded pretty similar. That being the case, even had people not preferred the VS, he could say, "The VS pedal wasn't quite as good, but could certainly hang with the others and it's a lot cheaper". It'd have been nice to have a few cheaper pedals in there too (Boss SD1, Digitech Bad Monkey, something like that). But then it's no longer a win-win for VS if the people thought those cheaper pedals could hang, too...
Even deciding how to dial in the pedal- how do you decide that? How do you decide that without bias?
Etc.
I mean, Bob Weil has a degree in business administration (according to VS's site), so if you think he hasn't thought of these things (or been taught these things)... A cynic might also say that more reasonable-sounding, less obviously biased propaganda/advertising is often more successful than more overtly biased stuff, because people are much more suspicious of obvious bias (e.g. totalitarian propaganda versus democratic propaganda in e.g. the cold war and beyond), and anyone with any sense realises that.
So yeah. A good vid, better than most? Sure. A completely ideal, fair, perfect test with no bias? Nope. If such a thing is even possible (and if it is, it'd probably be 8 hours long and put me to sleep).
Yeah the option of both would really be the thing. I suspect what's stopping that is the same thing that's stopping them putting decent buffers into (most) pedals- it'll cost them more, and very few people will notice or care.
And yeah don't even get me started on TGP. Yet another $500 "it's probably a clone" pedal is being fawned over as we speak.
I also post occasionally on the TC Electronic user forum - I've seen numerous users with 'problems' relating to bypass balance problems which, when you suggest they switch the unit to buffered bypass, 'mysteriously' disappear!
It makes me wonder why TC don't have the default setting switched to buffer on? True bypass certainly has it's uses but I think, for the average uninitiated hobby guitarist (who buy 99% of the products), a good buffered circuit is a much better option.
I guess the gist of what I'm saying is, just because I broadly agree with the findings doesn't mean I necessarily agree with the methodology.
Language can be a powerful and emotive tool, especially if your market doesn't understand concepts like cable capacitance and emitter-follower gain drop.
More to the point, what are you going to do if the switch fails in a TB pedal?
I tried that a few times and never got it to work (though I know of plenty of people who did). PCB layout isn't, from what I've seen, regarded as particularly important by most of the boutiquers - note the number of expensive pedals made on stripboard, or where the PCB isn't even secured in the pedal. I have a whole folder full of PCB design guides - the physical layout isn't as critical as in a valve amp, but can make a difference. Thus for a lot of builders adding another couple of components is a major nightmare.
The original Fulltone ones and the EHX Blues are actually fairly well made - it's the rush-to-the-bottom that followed that's resulted in 3PDTs turning into crap. But that's what happens when you take a switch that should sell for around £10 and value engineer it down to £3...
The only one I've had problems with was a cheap one I fitted to my Cry Baby to make it TBP with an LED, The replacement Alpha one has been fine so far but I don't rule out my overly hot iron and clumsy soldering technique in the failure of the first one.
