The strings thread through from the underside of the sustain block. They emerge between the locking screw and the two grub screws for saddle height adjustment.
If there is any string locking in the vibrato system, it will be at the machinehead end.
The two grub screws set the saddle height. The mushroom-headed Allen screw clamps down the string.
https://reverb.com/uk/item/24879181-wilkinson-wls130-s-f-for-off-set-intonation
