Hi all,
I've just picked up one of these very cheaply. It switches on, the valves all light up and it gives a signal. The pots crackle like hell, the gain in particular, but the biggest issue was the dead reverb. I unscrewed the reverb tank from its hideously dusty tolex cover and, after jiggling around with the red/white cables, found it actually works...a bit.
Questions:
What advice do you have on cleaning up crackly pots?
Can I connect this reverb tank to my Engl Gigmaster (it's easily accessible and has red/black cables connected which presumably are the inputs and outputs like the Laney one)? Are there voltage issues at play?
Any advice welcome. I'd love to restore this as what little sound I got was actually very nice.
Thanks,
Steve
My band, Red For Dissent
I wouldn't use wd40, it leaves an oily residue that attracts dust! Something like the interflon tf is a much better solution. I used to work on subsea oil and gas terminations, so I've seen the longer term effects on pcbs and potentiometers with using wd40.
I wouldn't use it as a first choice, but if contact cleaner doesn't fix it your only other option is to change the pot, so you have nothing to lose by trying it.
It very often does work, too.
