Valve Identifcation
SidNewtonSidNewton Frets: 667
Can the amp buffs identify these EL34's. They were in my Marshall JCM 800 when I bought it. The amp had been sat in the previous owners office for 10 years and as a result the inside was coated in dust and when I wiped it down I inadvertently remove the labels from the valves. They original had ITT Lorenz of them which suggest they are relabelled RFT's. I recently sold a couple of the ecc83's to ESchap and he confirmed them as RFT's, I've since found the other.
Can anyone confirm the EL34's as RFT's from the pics?image
  • ICBMICBM Frets: 74497
    Yes - usually called Siemens as that's the most common label they come with, although there are many others.
  • SidNewtonSidNewton Frets: 667
    I was hoping you might drop by. Thank you fella.
