I'm selling three UK made offsets. All three include shipping in the UK. Also happy to answer any questions.
Bridge - Gotoh Hardtail
Tuners - Gotoh Vintage-Style
Hardware Finish - Nickel
Bridge Pickup - Bare Knuckle Old Guard P90
Neck pickup - Bare Knuckle True Grit P90
Controls - Switchcraft switch and jack socket; CTS 500K volume and tone pots
Case- Hiscox Standard Electric Guitar Hard Case
Weight is 8lbs 1oz
Photos here - https://imgur.com/a/fwpf3yb
Selling for £875 including UK postage SOLD
SOLD - Jazzblaster (with new Fender CUNIFE Wide Range Humbuckers) - Nitro Finish and put together by Jon at Feline + Hard Case - SOLDI bought this from Tom (jollygreengiant) last year, and I've reproduced his description below:
Put together over the last year to be one of my bucket list guitars with no expense spared on spec and parts. Unfortunately, Jazzmasters are just not for me so moving it on to free up space and funds. Was put together and set up for me by Jon at Feline including. Plays extremely well, Jon rolled the fingerboard edges, cut the nut and also gave it his famous fretwork treatment. Body was made by Jon @ Rexter guitars and is a clone of his original 60's jazzmaster.Its got custom enlarged pickup routes for the wide range humbuckers.Jon also did all the finishing work - its full nitro finish in vintage correct sonic blue with matching headstock. Rear of the neck is matt finish with the rest of the guitar in gloss.Neck is from Allparts with the following spec - Rosewood fingerboard21 tall frets (.079 x .051 inch) 2.07mm x 1.3mm9.5 inch radius25.5 inch scaleNut width 1 and 5/8 inchesHeel width 2 and 3/16 inchesTruss rod adjustment at heelNeck thickness .86 inch at first fret, .96 at twelfth fret.
Logo on the headstock is custom from Rothko and Frost and has my daughters name rather than "F" and "Jazzblaster rather than Jazzmaster.- Tuners are Gotoh.
- Bridge is a Staytrem and 9.5" radius to match the neck.
- Tremolo System is a USA Fender one, same used as AVRI and 65 reissues, not the cheaper lower spec Mexican or Japanese version.
- Pick Ups are the new Fender CUNIFE Wide Range Humbuckers
- Pickguard was custom made
- Pickup Switch and Output Jack are Switchcraft.
- Pots are CTS
Will also come with a Hiscox Hardcase"Tom put the weight at just under 8lbs, but my scales (which are accurate) put it at 7lb 7oz.
It is a beautiful creation, put together really well with quality parts.
Photos here:
https://imgur.com/a/FbwlMCEI'd like what I paid for it -
£750 including postage in the UK.
SOLDTrent Model 1 (Bare Knuckle P90s + Tourtech Hard Case + Spare Pickguard)
Didn't think I'd sell this. It's really great. Just don't think offsets are for me (hence the three guitars for sale).
Handmade one piece obeche body. Weighs in at 7lbs.
A dark pau ferro fretboard.
Recently received a 9/10 review on Guitar.com and was nominated for guitar of the year.
Made in Dorset, UK with two Bare Knuckle Old Guard P90 pickups.
The current waiting list is 12 weeks and growing.
Comes with a spare pickguard in parchment if you fancy a change.
Key Features
DESCRIPTION Six-string solid body electric guitar, made in the UK
BUILD Obeche body, maple neck with 12” radius pau ferro fingerboard, dot inlays, 21 medium-tall frets and synthetic nut
HARDWARE Through-body bridge with bent steel saddles, Kluson Deluxe tuners
ELECTRONICS 2x Bare Knuckle Old Guard P-90 pickups, master volume and tone, three-way pickup switch
SCALE LENGTH 25.5”/648mm
NECK WIDTH 42.7mm at nut, 51.4mm at 12th fret
NECK DEPTH 21.1mm at first fret, 22.3mm at 12th fret
STRING SPACING 34.5mm at nut, 54.5mm at bridge
WEIGHT 3.2kg/7lb
FINISH: Broom Yellow
Photos here: https://imgur.com/a/qXl61RP
Withdrawn
As I said at the start of the post - any questions, just ask. Not really after any trades.
Cracking guitars!
