if you drill out the center of the dot it should be easy to remove the rest. be aware some dots are deeper than others.. Warmoth plastic dots seem to go most of the way through the board, most are only a couple of mm
Then install the new ones as flush with the surface as possible to minimize cleanup. you may still need to file and scrape the board afterwards to level off between the frets. This is a bit fiddly, but not too bad with simple dots
Instagram
