I've always used copper foil for shielding guitar cavities, but it can be a bit fiddly cutting it into shape and getting it to stick in the right places.
I was wondering if using conductive paint would be an easier option, though I understand it might require multiple coats.
I would also think it may be harder to make a solid connection to the paint as I'm not sure whether it's possible to solder to it, and I've heard that small pieces of paint can flake off and possible cause issues if it gets into the electrics and causes short circuits.
Thoughts?
I think it was Jonathan @FelineGuitars who recommended a more expensive type of paint than the big guitar manufacturers use - nickel rather than carbon, I think - which may be a lot better. It's easy enough to make a solid connection to it whichever type it is - a woodscrew into the body inside the cavity with a solder tag (preferably serrated/shakeproof) and a wire connected will do it.
