Gibson pots usually have split/splined shafts to accept push-on plastic control knobs.
It is possible to use a brass adapter ring over the splines but there is no guarantee that your chosen metal knobs will fit over the adapters.
But I’m pretty sure they’ll be for solid shaft pots only, in which case you’ll need the conversion sleeves that @Funkfingers refers to.
https://sixstringsupplies.co.uk/
Our YouTube Channel for handy "How-To" Wiring Tutorials
