I've had loads of valve amps over the years, but I've never bothered to revalve them.
To be honest I tend to flip stuff so quickly that it hasn't really been a problem and when I've had stuff blow up I've just taken it to a tech and had the specific valve replaced with whatever he has in stock (usually groove tubes).
As a result when people talk about changing their valves it's a bit of a mystery to me what the difference is between say a Winged C and a Tung-Sol is.
I've now had my H&K Puretone for a while and I figure it might be worth getting it revalved especially as it seems to only have 2 12AX7s and 2 EL34s so it shouldn't be too much money to get it redone and I do rely on it for gigs. It's also class A and as I understand they eat valves a lot more.
The way I understand it the power amp valves take a beating, but you don't have to replace the preamp ones all that often.
So my questions are:
* Should I bother replacing the valves at all, or just ignore them till they go bang like I have in the past?
* If I do will I get any advantage from replacing the preamp valves as well?
* If I replace them what should I buy and is it worth paying extra for expensive brands?
The difference? Sweet FA, I might as well have used mallards quite frankly.
However, I always revalve any amp I intend to use for gigging pretty well immediately, simple so that I have a complete known good set I can whack back in there in a few seconds. It really is just like having a couple of light bulbs in your kitchen drawer, it's silly not to.
or even a cathode-biased bigger amp which also normally don't need to be biased.
that's what i do )
it's odd, this. For the last few years i have routinely changed the preamp tubes in any new amp I've bought for old Mullards or Philips and in most of them the difference is night and day. Normally the sound is smoother, richer and with substantially less gain. But years ago I did used to have a couple of Carvins where I did this with no effect whatever. I have no idea why it makes such a diff in some and not in others.
I've never bothered swapping different valves around, but there are a/b comparisons that prove it can make quite a difference. I guess it depends on the amp?
Which is a tragedy - what if they're awesome?! It's the sort of product that needs plenty of extensive demos for before I'll realistically consider it.
If not and it's running mismatched into 16 ohms, it almost certainly isn't Class A. You can get 25W or even 30W from a pair of EL34s in Class A, but only with a correct match. If the correct match is into 8 ohms and gives 40W, it isn't going to be Class A.
I wouldn't worry about it though, it doesn't really matter as much as the usual marketing hype implies. Very few so-called 'Class A' amps actually are, and it doesn't stop them sounding good.
says Internet wisdom.
Blimey, it's a tidy looking amp!
I cannot find a schematic for that H&K, nor even a user handbook but this review..
http://magazine.dv247.com/2010/02/12/hughes-kettner-puretone-head-review/
does say that an 8 Ohm load will pull 40W and 16 just 25W. I can only conclude that the design has a very "flat" output impedance similar to a solid state amp? This is contrary to most valve amp characteristics which tend to put MORE power into higher resistance loads thus "beating" to some degree loudspeaker thermal compression.
I am also intrigued by the two small PCBs either end of the chassis? They each have a ferrite inductor/traff on them. Anyone shed any light?
H&Ks blurb does state that the amplifier is "Pure Class A". Make of that what you will!
Dave.
