SOLD FS/FT: Musicman BFR James Valentine Signature
TjoeTjoe Frets: 14
edited September 2022 in Guitars £
Hello everyone, i m selling this beautiful musicman, first hand owner, got it 2019 and went though lockdown, so didnt play much on it I ve keep it nice and clean come with case
selling at 2000 pounds
thank you
Specification:
Body Wood - Ash
Body Finish - High gloss polyester
Bridge - Music Man® Modern hardtail with vintage bent steel saddles
Pickguard - Gold Anodized
Scale Length - 25-1/2" (64.8 cm)
Neck Radius - 10" (25.4 cm)
Headstock Size - 6-3/8” (16.2 cm) long
Frets - 22 - High profile, medium width, Stainless Steel
Neck Width - 1-5/8” (41.3 mm) at nut, 2-1/4" (56.9 mm) at last fret
Neck Wood - Figured roasted maple neck
Fingerboard - Figured roasted maple w/ White Binding
Fret Markers - Block inlays
Neck Finish - Gunstock oil and hand-rubbed special wax blend
Neck Colors - Natural
Tuning Machines - Gold Schaller M6-IND locking
Truss Rod - Adjustable - no component or string removal
Neck Attachment - 5 bolts - perfect alignment with no shifting; Sculpted neck joint allows smooth access to higher frets
Electronic Shielding - Graphite acrylic resin coated body cavity and aluminum control cover
Controls - Custom Music Man® active preamp; push/push volume for gain boost, 500kohm push/push passive tone for custom spilt pickup configurations - .022µF tone capacitor
Switching - 3-way lever pickup selector
Pickups - SH - Music Man® custom wound staggered pole piece single coil (bridge) and humbucker with chrome covers (neck)
[admin edit - gumtree link removed]
