Has anybody used one amp but two different closed back cabinets together? What were your experiences? Do you know of any potential issues? Or I guess, any people who've run two amps and two cabs! I'm running a digital setup with a Matrix poweramp so that would be an option for me (though all my patches use one amp so far).
Currently I'm using a single 2x12 Mesa Rectifier cabinet. It is my favourite sounding cabinet however it is not without some issues - the biggest compromise is that it is very squat so ideally needs to be lifted up for easier monitoring.
I ran in to a problem last night at rehearsal where I was unable to raise it off the floor (the chairs were not deep enough to fit the cab + speaker cable). This meant I ran the cab louder than I'd want in order for the singer to be happy he could hear it. We're quite a loud rock band anyway, but I do try to keep things sensible!
I'm considering picking up a second 2x12 to sit underneath the Recto cab but I'm unsure what to get. Another Recto cab would be nice but they are expensive and I'm not sure if I want 2 of the same. I know my favourite speakers are Mesa V30s but I wouldn't mind having a second option anyway for when I don't want to run as loud. I do not want a 4x12, I've had 6 previously and I'd much rather stick with 2x12s for now for a number of practicality and tone reasons.
So to keep options brief, I guess I'm looking at 8 ohm 2x12s, ideally same depth and width as a 4x12. If I didn't get another Mesa I'd most likely go for regular V30s. I am however tempted by Creambacks, and K100s. Realistically the sensitivity of the cab doesn't matter too much as I can compensate for a lower volume cab by using the volume controls on the Matrix. This cabinet will be going on the bottom - should that affect my speaker choice? Possibly go for a mixed speaker cab?
Any ideas/suggestions welcomed and appreciated. Thanks.
I'm with ICBM (as usual). I haven't tried g12k100s but the other ones he mentioned work well with v30s in my opinion. I suspect the creamback g12h30 would too, but I haven't tried it. Might be worth considering if you want the g12h30 tone but without the limitation on power handling.
So are you still using my old 1960B @Moltisanti?
