What resistance value is the pot?
It is possible that repeated heating with a soldering iron has damaged the innards of the pot.
Pot is B500K
If all else fails I'll replace the pot.
Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
I've replaced the pot with a new A500K. Will check out the jack wiring later.
A common failure point is the rivet where the ground terminal is attached to the trackboard, often strained when the terminal is bent back to solder it to the casing. Squeezing the rivet hard with some fine-nose pliers will often fix it.
On this type of jack, if it's not being used for stereo or an active circuit battery switch, always connect *both* the ring and ground connections to ground - this greatly increases the reliability of these unreliable jacks by almost guaranteeing that the ground contact can't fail... leaving only the tip contact as the weak point.
But basically, you can always connect unused contacts to whatever they’re in parallel with to gain a ‘backup’ connection in case the first one gets dirty/corroded/stressed and isn’t making a reliable contact.
