I had a renown when I was 18, I had to get my dad to lift it up stairs for me! I used to love the channel blend on the renown, set both channels for a clean tone but with different voicings and then I used to run a rocktron blackjack through the front, I remember it being very loud and very cutting!
It was utterly bombproof. I used it as a suspension-softener in my landy, as it accidentally changed the orbit of a small planet as I drove past.
It sounded stellar, especially up loud. I just became unable to lift it.
I had one of those Peavey 'Deuce' amps in 1989. It was the Amplifier equivalent of a Drag Racing Car. A year earlier I had the 'Bandit' which aside from the speaker not liking me running it at or near full volume, was another great amp of it's time.
I know you can still buy new amps that are along these lines but I wish more companies made them like this these days.
It's also highly efficient, which combined with the high power, explains the astonishing volume level this amp is capable of .
and still at super low volume in my flat it still sounds incredible!
(probably).
To be honest, some of the higher powered celestion speakers can be had fairly cheap.
Or, it's cheap enough to use for funsies at home but gut as a head and use a 2x12 cab with it to handle the insane power (160 watts?! It must be louder than a 747!).
Or there is the stereo chorus...
