I enjoy building and repairing amps and other electronic doodads, and there are times when a dollop of gunk can be very useful to hold things in place, e.g. large capacitors. I have generally used hot glue for this purpose, but it may not be the best solution in places where it's going to get hot!
I have been looking for the following:
- Neutral cure silicone (does not release acetic acid);
- Clear rather than white;
- In a tube with a cap, not the cartridge that you put in a caulking gun.
Google has been little help so far. Do you use this stuff , and if so, what brand and where from?
TIA
You’re right about the online descriptions too, I’m having a hard time working out what is neutral cure and what is not.
I have been looking at the stock in DIY shops - at some point I’m bound to hit lucky!
old build i have.
