It was found very early on that you needed to block the motion of air pressure changes from the back to the front of the cone or else you got bugger all bass!
The ideal would be a baffle extending to infinity in the plane of the cone but a very good approximation was a speaker in a wall! Naturally some bright spark thought you could just put a speaker in a sealed box but you get nothing for nothing in this world and usually even less in audio! The result was a honky, resonant mess*. The open backed cabinet (as is every radio and telly!) was a fair compromise.
For guitar sound the speakers are big enough and we are unfussy enough that a (leaky!) closed box is accepted.
You would have thought someone would have done a thesis on rock guitar cabs but AFAIK they never have!
*Modern "IB" hi-fi speakers are a special case.
Dave.
Ooo! I hope you have secured the cable so that some drunk tripping on it does not rip the pigtails out of your cones!
Dave.
Well I don't know you see, that's why it would be interesting for someone to do the experiments. The very limited work that I have seen suggests that ported cabs with 12" guitar speakers do not behave "classically". I suspect that a lot of this is because the very light cone (compared to a hi fi woofer) is not very soundproof and damps the resonance?
Danny....STILL think the cable should be secured! But then I am a bit anal about such things......
Dave.
