New secondhand pickup hookup wire too short..
Is it OK to order wire and heat shrink and just splice onto the existing wires.. ?
I am not able to do delicate stuff with pickups,,so I can't replace the wires....
Splicing is the only way I can think of,,is it OK to do this.. ?
It may not be pretty but will the sound quality suffer... ?
I would have preferred if the wire was there of course.. Sh*t Happens..
It is just plastic coated wire on Fender Strat single coils...
Not the cloth wire..
What wire could I order that would be cheap and plentiful..
Or do I need special wire..? Groan..
  • WezVWezV Frets: 17495
    Splicing is fine, no disadvantage to it other than a slight reduction in reliability compared with an intact wire. That shouldn't be an issue if done well
  • KevSKevS Frets: 628
    With me done well depends on what way. the wind is blowing..
    All I see is wire that is cloth covered and sold in small lengths,,
    hand rolled on the things of Virgin Amazons....
    I am looking and it says 22 AWG..
    Is the wire sensitive about what capacitance it is.. ?
    There has to be something I can buy that is not expensive to buy a small reel..
  • ICBMICBM Frets: 74477
    edited May 2022
    For the wiring you need inside a guitar, gauge is irrelevant - the currents are so small that it simply doesn't make any difference. Capacitance is also irrelevant for plain wire, it's only shielded cable where it applies.
    A good source of wire for guitar work is an old Scart cable - they contain about a metre each of various thin coloured wires, which will keep you going for some time!
    I have violated a Scart cable..Very thin wire..Difficult to strip off the coating....
    I think I can manage it...Thanks for the tip...
  • TTonyTTony Frets: 28443
    That wire is too thin for cable strippers.
    Use a sharp blade, very gently.  VERY gently.  You’ll feel the difference when the blade finishes cutting through the plastic and gets to the wire underneath.
  • normula1normula1 Frets: 662
    If it's really thin I sometimes strip it between a thumbnail and index finger
  • LastMantraLastMantra Frets: 3826
    That's what I was going to say. Or teeth.
    LastMantra said:
    Or teeth.
    Can be unwise... I cracked a tooth doing that and ended up helping to pay for my dentist's new PRS.
    5reaction image LOL 0reaction image Wow! 1reaction image Wisdom
  • BillDLBillDL Frets: 9013
    edited May 2022
    If you can find an early 80s Made In Japan scart cable you will find that the insulated cables give you much sweeter tones
    @KevS ;; If you find the wire from the scart cable a little too thin to work with let me know roughly the thickness of the existing wires on the pickups compared with some everyday thing around the house and I can put a few lengths of slightly thicker wire in an envelope and hope that Royal mail don't intercept it as a suspicious device.  I have bags of wire in loads of different gauges that I have saved from various sources over many years.
  • FunkfingersFunkfingers Frets: 15262
    All this talk of cannibalising video cables, with inner insulation that is too skinny for easy stripping, makes the prospect of simply rewiring with new conductors at the bobbin soldering eyelets seem so much easier that it counts as cheating.
    edited May 2022
    First soldering Iron Burn in a few years..
    I just pushed on..Now I have a stiff and burny finger..
    It is still burning away..
    Like I've been stung by a hundred foot Wasp..
    Well maybe not quite..
    The scart cable just wouldn't take the solder..
    I found some other cloth wire luckily..
    I think I am going to invest in flux..
    I done two hooked U shapes in the wire,,then pressed it flat to join it,,
    then I soldered that....Then covered the joint in heat shrink..
    No way did Fender trim the wires that short..
    This is what was claimed..
    Even with a swimming pool rout the bridge pickup wire wouldn't have reached the switch..
    I had to lengthen all the wires so the wres would go down the middle rout channel..
    Also with the Stone tone pickups,,not only was the pickup wired wrong..
    The switch is knackered too..
    it wasn't quite before but it is now..
    It is intermittent between neck pickup,,or neck and middle pickup..
    When you get the neck pickup the inbetween position is silent..
    I am just hoping everything works with strings on..
    I only done the tap test on the pickups...
    So i will need a new switch..
    HMMM!! THink I have one I can Salvage..
    Another day though,,my head is mince..
    I think I will sell my Stonetones on..
    No offence against them,,they are just not what I am looking for..
    I have many pickups not in use..
    Time to sell them on soon I think..
  • prowlaprowla Frets: 5119
    edited May 2022
    Since you're going to buy some heatshrink, you might as well buy some 22 awg hook-up wire at the same time.
    "I think I am going to invest in flux".
    If you're planning on doing any soldering...definitely!
    I have heatshrink....I am dead modern me like..
    Although the same pickup set,,these ones don't sound quite as free and open as my other ones
    I already had...A little more squashed sounding..
    Don't know if they will open up a little..
    I'm sure someone will say,,that's impossible,,scientifically it can't happen..Burn him..
    If there was a tin of Flux that someone could recommend that would be good..
    Recommended Flux Anyone.. ..?
    Might as well get a capacitor to go with it.
    Fire up the DeLorean!
