Noisy DI Bass
I look after the music room we have at work.
Alas we don't have a bass amp, So I have the bass going into an underfloor snake (standard TS cable).
It comes out of of the floor and into a 48V phantom powered DI box, into an XLR input on the Behringer X32 mixing desk.
Whilst the level is good, it sure picks up a lot of noise.
None of the other line level instruments that go through the same snake (keyboards, drums, etc) pick up the same level of noise.
Any ideas?
  • fretmeisterfretmeister Frets: 24897
    What pickups are in the bass? Is it shielded?
    Can you not record the bass part with a short cable standing next to the desk? That's the easiest way.
  • octatonicoctatonic Frets: 34010
    What DI box are you using?
  • Axe_meisterAxe_meister Frets: 4712
    Not sure what it is. It was donated. It has two channels, with various dip switches for pad and phase.
    I've tried bass direct into the desk, via the AUX ins but am not getting any sort of level out of the bass
  • PolarityManPolarityMan Frets: 7405
    Do you need to put a battery in the bass?
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
    Just thinking theres a lot of juice int aht chain so amybe your amplifyingthe signal from an active bass that isnt being powered.
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
    Try it directly in a Mic input but start with the gain at zero and edge it up.
    The signals from basses is not very high at all.
    I've never done that at all.
    Not once.
    Never.
  • Winny_PoohWinny_Pooh Frets: 7900
    Put the DI in front of the snake and see
  • steamabacussteamabacus Frets: 1276
    Assuming the DI needs to be at the end of the snake as the snake isn't balance cable. I'd try a buffer of some kind at the beginning of the underfloor cable (a buffered pedal, eg Boss, turned off would work) to 'drive' the signal more efficintly.
