@funkfingers could I put this in the neck position? I mean sonically, would it work?
Obviously, the pickup will work in any position. The polepiece spacing is the same for bridge and neck. The covers are the same size. There is not a massive difference in output between bridge and neck.
The negative aspects are;
1) The magnetic polarity and coil direction will not cancel hum when combined with a second JM bridge position pickup.
2) If liftman's pickup has been removed from a Fender AVRI or AV guitar, the black conductor wire may be cut very short.
If the black conductor is shortened, on a regular Jazzmaster, you might get away with grounding the pickup to the chassis of the Rhythm Circuit slider switch.
@liftman I think I'll give it a miss, but thanks for the info
