Feedback thread: https://www.thefretboard.co.uk/discussion/comment/3575378
Ebay mark7777_1
I recently polished a modern poly guitar with plenty of scuffs and scratches. I got some out, but the finish is that hard that when I stepped up to using a drill with a buffing pad, I was in danger of burning through the finish in some areas.
If you can feel the scratches with a fingernail... like it stops the nail from advancing along, then most likely you'll need to use wet and dry sandpaper from 600 grit up to 1500/2000 grit to remove the scratches.
If they're just swirl marks then a couple of buffing compounds will do... for this I use Farecla G3 then Maguires Ultimate Compound for a mirror finish.
if it is deep scratches then the aforementioned wet and dry then
http://www.thefretboard.co.uk/discussion/61134/sarge/p1
