Welcome to the 20th Cover Challenge, and the inaugural Poopot's Cover Challenge
The rules are simple - there are no rules*
So I fired up the Ouija board and made contact with the winner of our last challenge, @poopot ;;;.
It took a while, as he was serving out a 72 hour bellend no communication ban as a result of repeatedly visting Paul Reed Smith in the middle of the night to tell him that tonewood isn't a thing for electric guitars, but he has spoken and he has chosen a track:
Girls Just Wanna Have Fun by Cyndi Lauper
If that's not your bag, and let's be honest it seems he is still trolling us all, then you can record any track starting with the letter G
But… if you cover the chosen track you will automatically receive a
bonus 5pts as a head start…
RULES:Entries to be sent in mp3 format to the following Email address:
covers@thefretboard.co.ukYou may wish to submit artwork to go with your entry. It brightens up the playlist and might subliminally get you more votes but it's not mandatory.
Entries close at 11.30pm on
Friday 23rd September 2022... get onto it!!!!
A playlist of all the entries will also be posted below and in the voting thread. Vote for your top 3 with 5 points awarded for first place, 3 points for second place and 1 point for third place. Entrants obviously aren't allowed to vote for their own entry
Warning : Swearing, there is swearing. And I guess I should put a trigger warning on it too.
https://soundcloud.com/thefretboard/sets/poopots-cover-challenge-g
As is the case these days, I don't think I will have time to contribute, again........gah
I kinda think that's the point (although I actually like it, but hey ).
Love it!
You might be less pleased if you're a Chris Isaak fan
FWIW all guitars were recorded with a jazz-tastic PRS Tremonti SE and a Boss GT-001.
And cheers to @Bezzer for very kindly providing shaker samples
I usually apply the reverb in the DAW, but I find it a bit of a mystery. It has a preset something like Room 1sec and I'll think I can barely hear it, but Room 1.5sec sounds like a canyon.
I find the best way is to use a reverb bus in my DAW.
There are lots of good tutorials but the principle is that you set up a track with a little bit more reverb than you need. You then route any tracks needing reverb to the reverb bus and you can then control the amount each track receives. Normally I have most tracks around -12 dB up to -6dB whereas this one was so much more it was giving me serious anxiety!
I think the best description of the approach with reverb is not to use your ears to listen for the effect, or by looking at the settings, but instead adjust it until each track, and the whole mix, "feels right"
Bit of background on this one as I did it a bit differently. I wanted it to feel less rigid so I recorded a full take just acoustic and voice ... had a 4 count so I didn't rush but then the click dropped ... I would no longer have a grid! Then I recorded everything over my roughed out version before eventually deleting that sketch. The result it's all a bit more loose but I quite like it.
Also meant I could not do ANY cut and paste, had to play every drum on the keyboard, could program nothing. Was quite fun.
Oh, and after months of doing very high vocals I went for the complete other end of my register so I sound REALLY different. I promise it's me though! I really hope you like it, I'm unusually pleased with it given it's a recording of me!
Little known track by a Seattle legend
It's not in my inbox and I sent my own test to confirm the covers address is working fine
